- May 18, 2023
- 96
- Plaster
- CircuPool RJ-45 Plus
I feel like the biggest idiot on this forum lately but here’s another question. I’ve looked at the pump run time article here.
Live in Phoenix. Pool is an in ground and 11,475 gallons, PebbleTec, liquid chlorine, no SWG, no heater, no spa, 3 2ft sheer decent water features, suction side robot with wall port, using a Betta robot for some surface skimming. Hayward VS950 pump and C4030 cartridge filter.
Can someone help me make sense of this flow chart from Hayward for my pump. I’m trying to determine best pump run time and speed to keep balance between having my water clean and costs low. Right now I’ve decided to try running 800rpm from 8am to 3:30pm for basic filtration and then 1500rpm from 3:30pm to 5pm while I add chemicals and brush. PSI is basically 0 here. I use the vacuum robot once a week at a higher speed around 2500-2700rpm and PSI goes to 8.
I was trying to calculate all the math to see what is best for my pool and TDH threw me for a loop. Pump to skimmer is probably 20 to 25ft apart. There are 8 maybe 9 elbows in the plumbing line. Plumbing is 2”.
Can someone explain this simply for me? If I look at this flow chart from Hayward it seems that 800rpm is probably too low and I should be between 2400 and 3000? That seems wrong to me and I feel like I’m missing something.
