Help making a plan to clean up the water
Spdif48
27
Turlock, CA
This turned out to be a bad plan. I've brought 4.5 weeks of SLAM to an end. Between chlorine and test kit refills I've spent pool store money and my CC is still consistently >0.5. I'll try again this winter when I'll lose less chlorine to sun and the everything is done dropping leaves in the pool.
Dirk
7,798
Central California
Pentair Intellichlor IC-40
No, since refilling my pool (from my re-plaster fiasco) and taking it away from pool guys, and by following TFP religiously, I've never had to SLAM, or even had a hint of green. My pool used to get some algae on the walls (when I used to pay a "pro" for maintenance), so I know the potential is there, but TFP has kept it clear. So I don't have any direct experience on what to do with solar during a SLAM. That said, my uneducated guess: since SLAM levels are safe for humans to swim in, I'm not sure what your concern is about the solar system. Algae shouldn't be growing without light inside pipes and panels, but since clearing your entire system of all algae, and all its nooks and crannies, is important to rid your pool of the green monster for good, I would be running "SLAM water" through everything I could, 24/7, including the solar system. Theoretically, if you don't do it 24/7, then even if there is no algae stuck to insides of the solar components, you'd still be "storing" water that is isolated from the rest of the SLAM process for periods of time. That might be counter productive. Keep all the water in your system circulating throughout the SLAM for maximum effectiveness.
Sidebar: this is anecdotal at best, but it's what I believe. I use Leslie's for chlorine. I have seen first hand how Lowes will stack new chlorine on top of old, so at some point someone is going to get stuck with expired chlorine. Seems like you have a handle on the date codes (when you wrote "60-day old chlorine") but the number of days is not all there is to it. If the pallet of chlorine is improperly stored, anywhere along its trajectory (while in the store, or before it gets there), its effectiveness could be compromised. Like if it had been left out in the sun for a length of time, or stored in a hot warehouse somewhere. Since I've witnessed Lowes' ignorance of chlorine storage first hand, I don't trust what they're doing, or not doing, behind the scenes. My Leslie's assures me that their chlorine is never more than a week or two old (which I suppose may or may not be true, but because it's a small store, they can't be hoarding a large supply like Lowes can). And I know for sure that they store it inside, in a back room, so it's sun exposure is minimal. Their price is competitive, so that is a non-issue. I'd rather be sure of the quality than try to save a few pennies at the big box stores.
That said, you can test both your chlorine's effectiveness, and the volume of your pool, simply by testing for chlorine just before you add it and about an hour later. If the amount you add gets you the expected result, then your chlorine is OK and your pool volume number is accurate. If you add chlorine and don't get the results you should, then either your chlorine is weak, or your pool's volume number is wrong. This only works once the pool is free of algae, of course. But the method can still apply to your SLAM process: keep adding and testing regularly until the SLAM level is achieved. Don't trust amounts added or pool volume numbers, trust only the test kit results.
Dirk
7,798
Central California
If memory serves, a CC number can be affected by other things. Unfortunately, I can't remember what all those other things are. Certainly a bad test kit solution, or sloppy test methods. But I seem to recall a CC test can show a false number if other things are present in the water. TFP experts, can you help me jog my ol' brain about that?
Spdif48
27
Turlock, CA
Thank you both for the follow up. The pool is free from algae, the water is clear and I passed the oclt. Since I stopped the SLAM and reverted to TFP chlorine levels I have been working on getting TA down. When my pH gets above 7.8 CC gets closer to 0 so I also suspected something was interfering with the test. I searched Taylor's site and came up with https://taylortechnologies.com/en/page/113/shocking-interference Since I don't know what the previous owner put in the water I might pick up a Taylor K-2042 and see what happens. I'm guessing whatever is causing the CC, be it algae, slime, fungus, The Blob or all of the above doesn't like the high pH but at the same time isn't bothered enough by it to either die or find another home.
I was excited to find the pool has an autofill. I also found what terrible things happen when autofill covers are replaced with decorative covers with finger holes. Here are the before and after pictures:
Note in the pic on the left I am holding the vac up to the equalizer line to keep the water level down.
Cleaning out the autofill didn't affect my CC numbers.
Dirk
7,798
Central California
That looks a bit like my auto-filler. Mine is a PoolMiser. Does yours have the overflow tube? Maybe yours is not being used and/or is plugged. My gizmo is both filler and overflow, via the equalizer tube, so my pool is never too low or too high. Very convenient.
A word of caution for you: I have had my "toilet valve" fail, though (and then replaced), so I check it at least once a week now (while emptying the skimmer basket). The valve can get stuck open, and if you have an overflow (anywhere in your pool), then you won't know the filler is running constantly unless you check it. Even once a week is too long, as that can be a lot of water. I turn off the system in the winter. And check it often in the summer. Fingers crossed. I may just replace the valve every few years, just in case. They're about $25. If your fill water has a lot of calcium, or other minerals, then that can eventually freeze up the valve. I think that's what happened to mine. I've since connected my auto fill system to my water softener, to control calcium build up in the pool water, with the added bonus that my autofill valve will be less prone to mineral build up (the same way water softeners extend the life of faucets and shower heads, etc).
