santacruzpool
Time to start your SLAM: First, lower the PH to 7.2 with muriatic acid. Second, add Liquid Chlorine to get to your SLAM value - per the FC/CYA Chart
Test the FC as often as possible and keep upping the chlorine back to the SLAM level of CYA 40 whenever it drops below that. The more times a day you can test and keep the FC at the SLAM level the better and faster it will clear up - the experts on here can help with any questions or issues that come up.
