Help please! Husband leveled wood to the level of foam boards under the liner. Then started filling pool last night. He knew he had to keep pulling the legs out to tight... but it doesn't look like he pull them out straight
The straps are not straight on the of the bars. The main concern I have is the pressure the straps will place on the legs because they are not straight. Some of the straps are only pulling/tight on part of the legs and gapping on the rest. I think we need to drain and start over, he thinks I'm over reacting and it will all be fine. Please help me determine if I'm crazy, or we need to drain and fix immediately. Included are pictures of how the bottom support strap is not evenly spaced on the bottom of the legs. INTEX 32x16x52 ultra frame
