[FONT=Lucida Grande, Trebuchet MS, Verdana, Helvetica, Arial, sans-serif]I opened the pool to a green algae mess because of a broken pump. Got everything fixed, and tested my chemicals. I had 0 CYA and 0 Chlorine. I have never had 0 CYA in past years, nor had I drained the pool so I figured I had ammonia build up. Before I added stabilizer, I was going to add chlorine until I could maintain a 1 or 2. I put a gallon liquid chlorine in 2 nights ago, and my chlorine reading was 0 the next day. Last night I put another gallon of liquid chlorine in, and today my reading was still 0. It was then I decided to get a clear bowl (5 quart) and put one drop of chlorine tester in. One drop turned the water yellow. I HAVE SUPER SUPER chlorinated. I wouldn't mind so much because the sun had been out and 110 degrees the past week, and it would have a chance to burn off fast with no CYA. However, it's cloudy and 80 this coming week. Question... Have a truly made a mega mess or is there a chemical that will burn the chlorine fast, or what do I do? Will this cause problems with my equipment, etc? Thanks in advance![/FONT]
