Went to the pool store today (I know, I know, just got on this forum so I was uneducated). Here are the results I was given:
Free Chlorine: 8.42
Total Chlorine: 9.04
PH: 6.8
Total Alkalinity: 67
Calcium Hardness: 503
Cyanuric Acid: 144
Phosphates: 4786 PPM
Husband has been "in charge" of our 30,000 gallon pool and was using chlorine tabs. I took over during this pandemic and am trying to fix some (little) green algae.
Added 10 lbs of soda ash yesterday. (before the test). Just added 10 more lbs.
Here are my questions: (and thank you in advance to anyone that can help)
1. We CAN'T drain the pool due to drought restrictions. What do I do about Cyanuric acid level if anything?
2. It's been two hours and the PH is not much higher even though I added another 10lbs of soda ash after testing was done at their recommendation.
3. Do I need to do anything else to fight the little bit of algae other than correct the PH so the chlorine (which seems high!) can work?
I promise to be eternally grateful for any help. Been trying to figure this out for about three days.
Free Chlorine: 8.42
PH: 6.8
Cyanuric Acid: 144
