Another update!
@jblizzle Thanks for the tip on shocking to mustard dose. That really helped the all day and night stay chlorinated until we got home.
Got home Saturday morning to a fairly clear pool. Was still a bit cloudy, but not too bad. Dosed the pool and ran the robot. Sunday did the same thing, although the pool was pretty much crystal clear! I am pretty sure I pass that part of the SLAM. I started my OCLT tonight as I have been seeing CC in the .5-1 range for a few days now. There is still some algae left on the bottom of the pool that the robot keeps missing, so I am going to manually vacuum that out. The numbers at the start of the OCLT:
FC: 16.5
CC: 0.5
TA: ~125
CH: 325-350 (I use the 10mL test for this, so it falls inbetween this range).
CYA: Unable to test atm as I am waiting on a reagent refill. Should be here this week. I think my CYA is fairly good as I am only losing a small amount of chlorine between doses as of now. I will probably still add some as my pool gets direct sun pretty much all day until sundown.
Hopefully I am almost done with the SLAM. It is going to feel super good.
