I have a 350 galloon Coleman inflatable hot tub and it's only a couple months old. In past I did chemicals all wrong so trying to kicked it off on the right foot this time. I read all the pool school articles but still have a couple of questions.
What I have done thus far:
1) flushed system with Ahhsome while filters floated in water
2) filled tub with water
3) tested water
FC=1.5
CC=0.5
TC=2.0
PH=7.2
TA=200 for true red got a purplish color at 180
CH=100 and did get redish color from R-10 and R-11L
CYA=20...I guess. Did it 4 times read articles about "glance" and batching the pours but never couldn't see and did it at 11:45 and had full sun.
Is my next step to shock (is that the same as slam) the water or plug my numbers despite wonky CYA into pool math and add based on that? Also what should I be testing daily and can I used the abridged chorine test or do I need to do the FC, CC and TC break out one?
I have young children so I want to make sure water is safe for them and in the past the water quickly went all over the place and I felt like I wasn't managing the process well. The hot tub is in the garage so no direct sun light and older kiddo routinely jumps in tub with little caution to getting debris off them.
Thank you so much!
3) tested water
FC=1.5
CC=0.5
TC=2.0
PH=7.2
Thank you so much!
