Hi all. I'm new to this forum and new to really paying attention to pool chemistry. I've had a pool for 15 years, but never had any major problems until startup this year. Let's just say I ended up draining, putting in a new liner, and having water hauled to refill. I ordered the book from amazon and plan to go through all the pool math and pool school stuff. But...I'm in emergency mode, as I want to start treating the new water before anything goes astray. Here are my numbers from the pool store test today (I plan to get the recommended kit, but need to do this until I get all that figured out).
FC - 0.81 ppm
TC - 1.07 pm
CC - .26 ppm
pH - 7.7
Hardness - 257 ppm
Alkalinity - 253 ppm
Cyanuric Acid - 5ppm
Copper - 0 ppm
Iron - .5 ppm
Phosphate - 1087 ppb
The pool people recommended nothing for the iron, even though the paper states I should add iron sequestering agent.
They recommended I add stabilizer first - 4 lb through skimmer.
They recommended I then add muriatic acid - the paper says 3 gallons; they said put in 1 gallon. Said I could add it after the stabilizer.
Next up they said to add 1 gallon of shock a couple hours after the muriatic acid.
I am now in pool chemical paralysis, as I followed a different pool store's instructions when I opened and ended up with a disgusting green pool and maybe chlorine lock. I don't know, but I couldn't fix it.
What should I do first? In what order? How much? How should it be added (For example - she said add all 4 lbs of stabilizer at once - but slowly - through the skimmer). Should I? I see contradicting stuff all over the internet?
The paper says to start with dealing with the iron concentration, then alkalinity, then chlorine, then stabilizer.
PLEASE HELP!
Thanks.
FC - 0.81 ppm
TC - 1.07 pm
CC - .26 ppm
pH - 7.7
Hardness - 257 ppm
Copper - 0 ppm
Iron - .5 ppm
PLEASE HELP!
Thanks.
