I have shocked the pool and run a few times as was very green. Pool itself is running fine however I have an issue with this fine sand / sediment that has settled at the bottom of the pool.
My sweep just poofs all the fine sediment up and makes the pool turn a much greener foggy color and essentially just mixes the clearer water with the sand. It then just settles again and we are back to the start.
How can I get rid of the sediment at the bottom of my pool? Is there a way I can drain the bottom of the pool or is there a different vacuuming technique I can use?
I’m stuck and really want to start using my pool now the weather is nice.
