- Sep 3, 2021
- 82
- Plaster
- CircuPool RJ-60 Plus
Now is the time for me to get the pool corrected. The previous owner used chlorine tablets exclusively and from their instructions they said to add one to the skimmer every two weeks. I ignored this and have been using liquid chlorine to adjust. The tabs had CYA in them, so my CYA is in the 140 range.
CYA - ~140
TA - 80
CH - 270
FC - 15
PH - 7.6
17500 gallons. My math tells me to drain and refill around 12,600 gallons to get CYA to ~40. I'm guessing the 1.5 HP superpump does about 80-100 GPM? Is that close?
No idea how long it will take with an average garden hose to refill. Any ideas?
After I refill, what is the sequence for tuning the water chemistry? Is it an automatic SLAM after a refill? Do I adjust everything but chlorine first and then do the SLAM? Or, since it is drinking water, do I just adjust the chlorine as per TFP???
How much of each chemical should I have on hand for the initial chemistry balance?
Looking to do this tomorrow if possible, depending on what the fill time might be. Thanks for any help and advice!
Brian
CYA - ~140
TA - 80
CH - 270
FC - 15
PH - 7.6
Brian
