Hello. I'm building a new custom home in Costa Rica on Pacific coast. The pool will have a water feature that spills into the main pool. My house is at 1,500ft elevation so pool can be a bit cool during part of the year so I am going to add some passive solar collectors.
I intend to use all Pentair and want to use the latest, greatest most energy efficient and most intelligent systems possible.
Goals/Questions:
Goals/Questions:
- Best Variable Speed Pump for pool. (Intelliflo3 VSF?)
- Variable speed control of water feature to be able to control volume of waterfalls back into pool. I May want to change the flow for noise or other reasons depending on how we are enjoying house at any give time.
- 2nd pump was the original thinking. What pump? Seems most water feature pumps are not variable speed. I guess normally these don't pump through the filter so are "low head". Is this what I want?
- Possible to consider using just the one main pump and a variable valve to control water feature? Are the Intellicenter controlled valves just on/off or can they be partially opened by Intellicenter?
- Thermostatic control of when water is routed through passive solar collectors. I'm sure a diversion valve can be controlled with temp sensor, right?
- Full home automation integration with Home Assistant. I assume I want the Pentair IntelliCenter to do this though there are many IntelliCenter part numbers/versions.
- 2 zones of lighting (main pool and water feature). Each separate control including color control. (Lights planned are Pentair Micro-Brite). This goes through IntelliCenter as well I think.
