If a FC of 13.5 with a CYA of 50 effected you, then I would suspect either the FC is higher or the CYA is lower.
The active chlorine in your pool, if the FC and CYA are correct, is not harsh in any way. Now the pH -- that could be an issue if it was not started at 7.2 or you have done this SLAM for a very long time.
For a Deep Read on FC, CYA, and their relationship -- see -- Pool Water Chemistry
Just to verify my results. I mixed the CYA reagent as directed.
Here's the view tube at 60 and 50.
