Probability is that the bleach is fine from Wal Mart. The biggest obstacle during a SLAM is the sun (if you add during hot sunny days) and how quickly the chlorine is consumed. It is recommend that you test, add according to pool math to SLAM level and continue this process. No need to try to figure out all the extra. As the water turns from green to cloudy and then to clear, wait a few more days with filter running. Once the water is clear, allow levels to drift down under 10 before you perform the OCLT. There has been some testing error, with higher levels and you could loose 1.5 to 2 ppm, which would mean that you failed the test.
Allow the levels to drift down under 10 and perform the overnight. If you find that more than 1 ppm is lost overnight, then continue the SLAM. Take your time with the testing to ensure consistent drops, etc. Also, PH will test accurately. Please keep us posted.
