In your 15K pool, a full 4lb container of stabilizer would increase your CYA to 32. If your water is still crystal clear and no signs of cloudiness or algae, then "yes" - we would increase CYA to 70 for your SWG pool. That would require another 5 lbs of stabilizer. The key here before you increase CYA is to make sure your water is clear with no cloudiness or anything that would require you to "SLAM" the pool. We like to SLAM at a lower CYA to use less bleach. But if everything looks good, then definitely increase the CYA right away. Your SWG is probably struggling to make FC without enough protection from the sun. Make sense?
While that is happening, remember you can always add a little extra "regular" bleach to the water to help augment the SWG. No problems there.
