I can't seem to get the recommended levels.
jdubh
12
mn
I installed a Bestway steel ProMax 16'x48 above ground pool from Menards a few weeks ago. I also bought the tf-100 test kit.
I have added liquid chlorine multiple time to raise my free chlorine and it significantly drops within 24 hours. I added some conditioner per the pool math app, and it did not do much. I have also added muriatic acid a few times to get the PH down.
My question is what I should fix first PH, FC, CYA, or Ta?
My water clarity was very clear up until a few days ago. It is now a light blueish green, and can barely make out the patterns on the bottom.
My PH goes from 7.2 to 8.1 in 24 hours
7-27 test results
PH 7.6
FC 1.5
CC .5
TC 2
CH 300
TA 280
CYA <20
Hey there - we have the same pool and same test kit!
Blue-ish green water + loss of FC = leads me to believe you're running into an algae issue.
Get your PH down to 7.2 and start the SLAM Process
-or-
If you feel it's a fluke, try Overnight Chlorine Loss Test
Do you use the PoolMath app? If so, sync your app account so we can see your logs.
-or-
How do you sync the app to the account? I did go to settings in the app and check "link from Troublefreepool.com", but I do not see anything in my profile that shows my logs.
