I moved into a new (to me) house with a pool. It’s a pool with a spa, about 18K gallons, according to my rough estimates. It has a Jandy 2HP ePump, a Jandy CL460 cartridge filter, and a Jandy Caretaker in-floor cleaning system. I recently learned how to access the iAquaLink 2.0 programming software.
One of the issues I troubleshooted recently was that the pump would not turn on and off according to the schedule on iAquaLink. One recommendation I found online was to clear the memory and reprogram it, which I did earlier today.
Tonight I noticed some issues with the pool pump, and I’m not sure whether it has to do with me reprogramming the system. The pump’s pressure is about double (20 psi) what it usually is (8-10 psi), even at lower speeds. I can’t feel any pressure coming from return jets. The spillover from the spa into the pool, which runs when the pump is running, would surge and retreat, and then by the end of the evening, there wasn’t much spillover at all. Just a trickle.
I installed new cartridges last week in the filter, and tonight I cleaned the skimmers and pump strainer. Nothing seemed to help.
Any ideas on what to try next? I’m worried about not being able to circulate the water in this 100-degree Texas heat.
