Date | 5/29/2020 | 5/29/2020 @ 11:45pm | 5/30/2020 | 5/31/2020 | 6/1/2020 |
Time | 11:45 AM | 10:43 AM | 2:44PM | ||
FC | 0.4 | 0.2 | 0.2 | 0.6 | 0.4 |
CC | 0.4 | 0.4 | 0.6 | 0.6 | 0.4 |
pH | <7.0 | 7.4 | 7.2 | 7.1 | 7.3 |
base demand | 9 drops | ||||
total alkalinity CaCO3 | 90 | 125 | 100 | 150 | 125 |
calcium hardness | 270 | 250 | 250 | 275 | 250 |
cya | 75 | 80 | 65 | 70 |
What was your FC level before your added the 4 gallons? According to pool math, you added 28ppm of FC. If that was your target did you start at FC of 0?Hello again,
I have a problem reading the FC. After an hour of adding 4 gallons (12%) of chlorine to reach 28FC SLAM target, I ran into a problem with testing. I used 10mL, and after the water turned pink with two dippers of the reactive powder, I started the drops of R-0871 but the water did not change to colorless. I stopped adding drops around 80-count, the water was almost dark orange. According to those drops am I at >40? My kit is brand new...what am I doing wrong? or did I add too much chlorine?
