- Feb 26, 2021
- 26
- Plaster
- Jandy Aquapure 1400
Yes, I kept the same water that I made w/ the test and added 5 drops 0003. The water was still clear after that.
As for the CYA, I did as directed and just kept putting drops until I couldn't see the black dot. By the time I couldn't see it, it was upto 33 on the test kit tube(smaller sized one). It saids on here CYA and it goes from 100 to 30. I needed to fill it until about 33, close to 30 for me to not see the black dot.
Okay I will look at the manual and see how much muriatic acid I need to add to the pool to bring it down. I don't know how much to put in yet...
And yes! That completely makes sense about Leslie's and other pool stores. I always like learning about things by myself first. Also this is our first house so I'm super excited to be able to take care of the house, even though it's a lot of work. Seems like I just need to add some acid and I'll be all good then? The pool doesn't have any algae or build ups from what I've seen. I'll bring down the PH and start using it.
Thanks for all the help!
Let me know what I need to do about the CYA. Not sure if that's safe.
