Planning on some equipment changes in the next couple weeks. My 30inch Hayward sand filter has a crack in the lip and the MPV also has cracks at the base and has been leaking for a few months. Spring is coming and I need to get a new filter. I've done a lot of research and have decided on the Pentair Quad 100 with no backwash valve. I just plan on cleaning off the filters 2-3/yr.
I really like the idea of the "hybrid" filter and moving up from sand(which I thought always did a really good job) to DE should improve the water clarity even more.
I'm also installing a Hayward Ecostar 3400 vsp 2hp. Don't beat me up too much over that!!! I picked it up used and pretty cheap.......and long before I did any research........ and after everything I've read I think I know why it was so inexpensive!! However, it's a 2018 model and there is some thought that the motor drive issues were fixed by then??
In any case, I thought I'd give it a try since I'm already out the cash and if it doesn't work out I'll swap it out for something more reliable. I'm doing the installations myself... so no labor costs.
My goal is to also replace some of the aging, sun damaged pipework and try to figure out what one of the valves does. I'm also thinking of installing a Flowmeter and was wondering how helpful they are in figuring out what speed you need your pump to be running at.
I bought the house with the pipe work just as you see. Any thoughts on how to clean it up some? Maybe it can't be done without a ton of work...
