- Feb 16, 2021
- 48
- Vinyl
- Pentair Intellichlor IC-40
Hello from Ontario!
I'm Dave, and I've tried to read many many posts here, and thought I better sign up as I still have lots of things to learn!
I grew up with a pool.. but being a crappy son, I didn't really help out much to maintain them, so not very knowledgeable.
I mean I vacuumed, helped open and close.. But I didn't do any of the chemistry..
I do know the Cost to build a pool is CRAZY compared to when I was younger. ( okay - I'm almost 50, so maybe comparing a price from 35 years ago isn't fair !
Anyway..
I contracted a pool builder ( They're all so busy, it was a real challenge ) and the job was officially started November.
This pool will be a custom 32 X 14 vinyl lined, salt water. If I calculated it correctly it's about 12,100 gallons.
The layout is a 7'L x 10'W, 1'D tanning/baja ledge that drops off to 5'D "deep end" Deep end is 18'L X 14'W and it leads to the "shallow end" which is 7'L x 13'W and is 3'D.
The shallow end will have vinyl over steel corner steps.
Beside the tanning ledge will be a portable Hot tub ( marked with an X )
Something like this...
pb equipment:
Pentair SuperFlo.. that I upgraded to be a IntelliFlo ( because I wanted an IntelliCenter )
AquaRite/Low Salt - Salt Water Chlorination( T-15 Cell )
Raypak - RP2100 Heater
Current situation..
The pool shell is complete ( gunite / concrete bottom and steel walls) and backfilled..
Coping is in and Forms are in ready in most of the yard.. retaining wall is done in sitting area.
They built a 2' High table in the deep end put straw all over inside the pool.. then they double tarped.
All plumbing and bonding wire and 2 conduit for 2 gloBrite pool lights are all pulled back to the equipment pad.
2 Natural gas lines were put in for a fire table in the sitting area and a fire pot that will be on 8'L , 4 sheer feature wall.
Project is now waiting for spring thaw to continue.
Problems....
I told them I would hire someone to do all electrical ..as they wanted to change almost 7,000 for electrical work..
That was just a subpanel...no automation and all equipment wired to it.
The Pool company is INSANELY expensive on certain things.... so where I can I am doing it myself ( or at least organizing it )
All prices in Canadian Dollars..
For instance.. My Heater they quoted $7850 tax incl for a Raypak - RP2100 dig./elect. 266k BTU
Break down was:
450 Electrical hookup.
3,050 Natural Gas Line and Connection.
4,350 for the heater.
So I went shopping.. and bought the same heater for 2,800 ( yes even with Covid19, I scored one of the very few available), & I contracted a gas company for the Natural gas run $1600.
I really feel I am being fleeced on their "hook up" charges...
I asked them about automation and they said another 5000 - 6000 ..on top of the original electrical quote and it would be an easy touch..
I went shopping...
I have an IntelliCenter I5P-C SINGLE BODY CONTROL W/ SCG on order ( 2800 Tax incl ) .. a friend's brother is a dealer
I "think I want" IntelliValve(s) for my Feature wall.
Things I don't know..
I don't have a spa.. but in the future I do plan to buy a portable Hot tub that I am hoping I can just use the breaker space in the IntelliCenter ( 220v 50 amp requirement ).
AquaRite .. The PB says me this is just a plug in and kind of forget once it's running ..so no worries if not compatible to IC.
The amount I have read.. suggests this is not true.. but I have also read it is compatible to the IC..
They're billing me 2600 for this installed.. ( not incl. electrical of course )
I kind of Feel the IC40 is similar and maybe I should see if that is an option.. should it cost about the same?? Or may be it really doesn't matter??
I think the IntelliPH looks interesting... can I run that if I don't have a IntelliChlor?
Okay .. so that's about all ... As you can see .. I like shopping for a deal.. and I am really really open to suggestions!!
Thanks.
Dave!
Anyway..
pb equipment:
Current situation..
Problems....
Break down was:
I went shopping...
Thanks.
Dave!
