I have an in-ground concrete pool located mostly in the SHADE , it's ~ 25 x48' (Roman Shaped).
We had a heat pump for the past few years, but it broke (seems the installer didn't set it up perfectly flat and over time collected water which corroded the parts, and replacement part is very expensive)
I could just buy a new one as the electric lines are already installed. However, ...
I'm thinking of going to a gas heater, as with the electric heat pump - I needed to start the heater early in the morning and since it uses the existing water pump - I couldn't run the filter overnight (cheaper rates) as I'd need to run it anyway during the day for the heat pump. And overall the satisfaction with the water temperature was good not great.(I would have gotten better results with a solar pool cover, but we tried but couldn't stick to doing it nightly, and an automated one is too costly).
So I'm thinking of going to gas. My pool runs parallel to the house in the back yard and begins approximately 30' from the house. and my water pump/filter is approximately 65-70' from the house.
I called the local gas company and it seems that my gas meter is "250" I asked if that was BTU's she said no, so I'm guessing (via google) that's AL-250 which < 350k BTU
I'm guessing for my size pool I'd need a 400k BTU (let me know if I should get more)
The Question is - that due to Covid - the gas company can't guarantee me that they'd be able to install the new meter this summer.
So my Q #1 is should I buy the larger 400k BTU heater and run it with the existing meter? (we like 80 water temperature, and without the heat is ~65 degrees)
Q#2 - given my setup, distance from house, etc - shoudl I just stick with electric or go gas (comfort and cost)?
thx
thx
