- Jul 21, 2013
- 66,140
- Plaster
- Pentair Intellichlor IC-60
One final question (at least for now): If the resistor test indicates that the new Pentair thermistor is not defective, is there anything else that might trigger the "E01" error code (& prevent the heater from firing) before I replace the circuit board?
E01 code is an open water temperature sensor. The wiring between the thermistor and the board could be at fault.
Carefully check the spade connectors that slide onto the thermistor.
