Hot tub circulation pump stopped running after a power outage, was still humming so I tested capacitor and it was dead. Replaced capacitor and then the main breaker kept tripping. Disconnected heater and breaker stayed on. Not sure if I did something while tinkering with the pump but definitely seems the heater is now the problem. The element has continuity - got 16 ohms on the multimeter and has no visible corrosion etc. It is a Balboa 58104 4kw heater. Is there something other than the element that can cause the heater to be tripping the breaker? Like I said the breaker stays on and the pump will run fine when I disconnected the heater element from the board.
