Hi Everyone,
I'm having issues with my Pentair Max-E-Therm 200 heater. Its about 4 years old and has been running perfect until this weekend. The heater will start up, the blower activates and then I hear the flame fire up. After 10 seconds it shuts off and there is a knocking sounds coming from the manifold. I've removed the plumbing and it looks like the Manifold bypass is in tact. The Thermister was tested in a cup of boiled water and it appears to work as well. My variable speed pump runs at 2000rpm when the heat mode is active. The only way to make the heater work is to run the pump at full speed, which I've never had to do. I cleaned the filter and checked the basket, there does not appear to be any issues with water flow. Before I place the service call, any other troubleshooting tips I can try? There are no error lights except a very brief flash f the PS (Pressure Switch) which I have tried to bypass as well.
Thanks
Thanks
