DrewLG
- May 31, 2022
- 674
- Plaster
- Pentair Intellichlor IC-20
There's a lot of other stuff going on that I'm sure you want to solve first... But if I understand you correctly, you're saying that you want the pump to run more slowly with the heater on than with the heater off. Is that right?I did set a feature to run pump at lower rpm/gpm when heater is activated versus than running at whatever rpm set in other pump feature setting.
If so, make sure that when the heater is on, the flow through it is in the range specified by the heater user's manual. It probably wants around 40-50 GPM, which for most installations is on the higher side of pump speeds.
