I'm a new pool owner and, to date, I have had the heater bypassed because it needed a new manifold installed which the previous owner had and never installed. He was nice enough to install the part for me and I have now plumbed the heater back up. No leaks after turning the pump back on. The heater is an old natural gas laars lite 2. I found an owners manual online (below) I have a few questions before I fire it up for heat.
I connected the water pipes simply with schedule 40 pvc by using a threaded to slip pvc fitting right into the inlet and outlet 'ports'. When I look at the manual , it shows to use cpvc nipples out of the heater when using plastic pipes and to use plastic inserts when using threaded pipes. . I used neither only because I couldn't find them anywhere on the holiday. Again, I have no water leaks the way I hooked it up.
I assume the cpvc is precautionary for temperature but schedule 40 is rated for 140 degrees which should be less than the heater puts out, right? Any issue there?
I assume the plastic inserts are for a proper seal With the gasket when using threaded connections? Any issue leaving line I have it so long as I don't get leaks?
Here is a link to my heaters oweners manual: http://manuals.chudov.com/Teledyne-Pool-Heaters/Teledyne-LD-LG-Owners-Manual.pdf
thanks for any advice!
