- Aug 13, 2022
- 100
- Vinyl
- Hayward Aqua Rite (T-15)
I have a JXI400P Gas Heater and recently I've been having weird issues; most notably it isn't actually turning on. The app says it is, and the light is on, but the fan doesn't come on.
I've done some reading and it seems like it's probably pressure, so I swapped to a pump profile for 2750 RPM and it came on. I'm seeing a lot of diff results on what PSI or RPM is needed to make it work, but most say something in the lower 2ks (The default for Jandy is 2250), but also mention 30PSI; which I almost never have ~20-25 PSI; which the gauge says is 'clean'.
I plan on cleaning the filters (cartridge) this weekend as perhaps that is ruining some of my pressure, but I'm unsure if I should have Jandy come out to look at it, or if it's simpler.
My pool has 2 returns, 2 drains, and a skimmer. Drains+Skimmer are both open at equal pull. Returns are ~90% to the pool, 10% to the spa.
Someone also mentioned you should "ensure the valve to the heater is all the way closed" but I don't have a valve for it that I see; not a manual one anyway. Here are pics of the pad - For plumbing on most Ts the right side is 'spa', left side is pool. The weird manual valve in near direct middle is like that to ensure the spa always has "some" water returning, regardless of the actuator mode. Was a mistake by the builder, but I found a use for it.
Welcome any advice.
Welcome any advice.
