I'm trying to plumb a heater by-pass and I've run into a problem. My initial idea was to insert a 3 way valve between the input and output pipes of the heater but they are way too close together. So I came up with the solution of sending the bypass up in a loop.
Now I realize my 3 way valve doesn't support either of these ideas. As you can see in the attached photo, the valve inlet is in the wrong place. I need the water to come in from the right port and I need to be able to shut off the upper and left ports. I'm looking at Jandy's website and I don't see a valve that does this.
Or, do I have the plumbing wrong? I can't see how I can use this valve without plumbing in a lot of elbows.
See photo below. Everything is dry fit and I realize I don't have the bypass loop lined up. I had to make adjustments after realizing the SWG cell is much bigger than I thought.
