Being a new pool owner I've logged some strange data over the past six months that took me a while to explain. One of them was filter and IFCS pressure. I knew pump rpm would have a significant affect on pressure but I didn't realize how much of an effect the heater bypass valve would have.
When we bought our house, the previous owner had the heater bypass valve set at the 50/50 position. At 2,750rpm, filter pressure was 17psi and IFCS pressure was 11. I log this to see how pressures are affected after cleaning the filter cartridges. Today I bypassed the heater entirely and the IFCS pressure jumped from 11 to 17psi! The IFCS jets are really moving some water this morning! I figured changing the heater bypass valve would make a difference but not that much.
When we bought the house the IFCS was set to run for four hours per day. I dropped that to 1.5 hours for a few weeks. Pool was still spotless. After calculating how little it cost to run the pump at the higher speed I use for the IFCS I decided to bump my IFCS run time to two hours. Now after seeing how much better the IFCS water pressure is with the heater bypassed I'm tempted to either drop the pump rpm or run time.
I continue to learn new things about pool ownership each week. Mainly from the amazing folks here but sometimes I stumble on it by myself.
