Hoping someone can guide me in my troubleshooting here, as I feel like I've tried everything.
My Pentair Ultratemp single phase heat pump trips the breaker when the compressor tries to turn on. It starts up fine, fan runs through the whole 5 minute delay, then the moment the contactor for the compressor activates, it trips the breaker... too quick for it to throw any error codes. ALSO, I found that while the fan is running, electric is escaping somewhere (when bending over to look at the display panel, I put my hand on the top and thumb touched a screw on the panel and I got shocked ... then I found that the whole metal wiring casing is live). I've tried:
- Checked all wires are fully on their locations - all look brand new and none are chewed, rotted, etc.
- Replaced the 60a breaker at the box
- Tested capacitor, which was fine, but replaced it anyways
- Checked and tested compressor, wiring from panel to capacitor is fine and not corroded inside, all amperage between posts test correctly ... it's not shorted to ground.
- I grabbed an HVAC tech working at my neighbor's house just to verify these, and he confirmed the compressor is good and not shorted to ground.
- He confirmed all wiring looks good, checked the other components that wires are attached to, and all look great.
- We swapped the two contactors in case the main one for the compressor was the problem, but that didn't fix it.
- He noticed the unit wasn't grounded, and he had to run back to the other job but didn't see anywhere the electric could be escaping from...
- So I ran brand new main lines with ground line from the breaker to the unit
- Label on the side says manufacture date of Nov. 2013. I know it's near the end of its 10-15 year life, but would rather fix than buy a new compressor or unit.
- The little temp sensor has been replaced twice in the last 4 years
- The compressor is quite rusted all around the bottom mounts ... could that be the place that the electric is escaping from?
- Could the refrigerant levels affect this?
