Hayward 1.5 hp pump, sand filter, RayPak 125k BTU heat pump.
Disconnecting the input from the heat pump and directing it straight into the pool gives a filter pressure of 10 psi.
Running the pump with the heat pump connected gives a pressure of 15psi.
Previously, without the heat pump, the running pressure was about 11-12 psi.
So, by the looks of things the heat pump, and the additional fittings on the output to the return line adds a 3-4 psi of back pressure.
I'll try to get pictures up, but I admit my plumbing of the heat pump looks attrocious. Too many elbows and fittings. Reason being is that no one seems to stock the LASCO unions required for the heat pump. So I had to frankenstein together the bits from the installation the previous owner of the heat pump had.
Now, I was flabbergasted to find the original installation kit in the bottom of the heat pump. SO I now have the required fittings gratis.
Would it be worth the time, energy, and importantly, money, required to replumb the heat pump better?
Would use 2 inch pipe and fittings everywhere except for the transition from the filter pipe and the transition to the pool return and add two 2 inch isolation ball valves, a 2 inch bypass ball valve, and a check valve.
