Hi, new member here . I'm in process of getting a quote on 40x20 (maybe 36x18, yet to be tetermined) inground gunite pool.
I'm pretty much all decided on all opitions and features except one. Don't know which way to go on the pool heter.
The property doesn't have NG so heat pump or propane are the only options. Currently have 500gl inground propane tank that serves standby generator and tankless water heater in the house
The goal is to keep pool at constant 85-ish degree temp. For the entire season. The pool will have auto cover. The pool location will have about 9-10 hours per day of direct sun.
So the questions are:
1. Will 500 gal tank suffice to heat the pool and support stand by gen and tankless water heater and how much propane will i use per month to maintain 85-ish degree temp?
2. If I go heat pump route by how much my monthly elctric bill will increase?
I'm ready to eat reasonable one time higher installation costs if I have to. The main goal is lower operational costs down the road.
Would like to hear real electric/propane monthly $ bill numbers from owners of both systems. I know technical pros and cons of HP vs propane but would like to know which one would be cheaper to run in my case?
Thanks
Thanks
