- May 23, 2015
- 25,718
- Plaster
- Pentair Intellichlor IC-60
I will say this about home HVAC choices - you will need to pry my forced air gas heater from my cold dead hands before I ever use a heat pump to heat a home. When we lived in a pricey coastal CA apartment community, every unit had a heat pump for heating and cooling. It worked ok in the summers but was terrible in the winters. I complained endlessly to the apartment management office about it and every time they’d send someone out and they said it was working fine. I would stroll by the unit outside on my way to throw out trash in the winter and routinely find the heat pump frozen up with frost and ice. I would send the pictures to management and they’d always reply - “our technicians say the unit is functioning properly” … hahahahaI don't think anyone would be swimming if a pool heat pump had a negative COP. It takes a lot to bring even old, inefficient heat pumps to a negative COP. From what I've read, I can probably expect the heat pump at my current rental (there's no gas to my rental unit) to be around 1.5 even in the 20's °F ambient. Modern (house heating) heat pumps can maintain positive COPs to -10 °F or below. (of course this is considering a typical house at 68 °F, and pools are heated higher than that)
I have a friend here in Madison, who's considering getting rid of (natural) gas in his house and going with air source heat pumps. I did some research for him literally just now, and concluded that operating cost wise (not counting equipment, install, and maintenance costs), he'd probably break even compared with his 80% efficient gas boiler when switching to a very high efficiency air source heat pump. Yes, I did those calculations for up here in Madison, WI.
This was based on a heat pump being able to obtain an average COP of about 2.25 at an average daily temp of 20 °F (our average daily temp for January), and 2.5 at 25 °F (Dec and Feb). At a COP of 2.5, and our current prices the operating cost is a break-even between a heat pump and his 80% efficient gas boiler. So for this example, with a very high efficiency heat pump, compared to an 80% efficient gas heat here in Madison, you actually end up only paying more in January, break even in Dec and Feb, and have cheaper heating in Mar, Apr, Oct, and Nov.
Average temps here in Madison:
COP vs average daily temps from a test house in Connecticut, for a very high efficiency air-source heat pump:
Obviously this is a very high efficiency air source heat pump, and pool models are simpler, single stage fixed speed pumps. But it looks like the Raypak models get a COP of 4 at 50 °F ambient, 80 °F pool water still. At my rates (and this will vary wildly), as mentioned above, you only need a COP of 2.5 to break even in operating cost between a heat pump and an 80% efficient gas heater, which would be typical of a gas pool heater.
Now, the big thing here, besides local rates, is that a 400 kBTU gas heater can heat a pool much faster than a 120 kBTU heat pump, so you can heat as-needed much more easily, and heat loss is proportional to water temp, so shutting off between uses (like any heating application) will always save money. So for most people they'd be better off with a gas heater and heating on-demand. But for those that want a pool always ready to swim, it's probably going to be difficult to beat a heat pump.
The other thing is rates vary a lot. For pure heat component (not accounting for efficiencies), right now with my rates gas is 1/3 the cost of electric. When I calculated this a couple years ago, it was 1/5th, which changes the equation a lot.
I wonder how long until pool heat pumps start getting variable speed compressors.
We finally got fed up and just ran space heaters instead. Figured I was wasting just as much on electricity either way. So that was my one and only experience with heat pumps which lead me to my opinion that I will never own one. Give me NG, propane, or No. 2 fuel oil … at least those things have well defined heat contents
