We'll be packing the minions in the Rav for a week on Long Island starting Sunday. I've been going back and forth in my head about my vacay strategy for the Intex-- pucks in a floater, auto-dosing, getting my pet sitter to take care of the big pet too....
I've thrown together a simple gravity fed dosing system controlled by an irrigation timer which I've been playing with for the last few days. So far it seems consistent in the chlorine dosing, but with so many components in the mix, if one fails (or there is a power failure of epic proportions) then it all shuts down. Granted so will the filter.[emoji854]
I will likely have the sitter look at the pool each day to monitor things, but with three dogs in her care, she'll have a lot going on already.
Pucks are a simple solution, but working out how many to add is dependant on how long it takes for the pucks to dissolve. I don't use them often. Pool math tells me how much trichlor to add to cover my 2ppm daily usage, but that doesn't guarantee 2ppm is dissolving into the pool daily. From past use, it seems it's about a week and the pucks have dissolved mostly, but not sure if temp/FC levels affect the rate they dissolve.
The forecast is calling for days in the 70s and a couple of low 80s while we're gone, so CL usage shouldn't be insane.
Q1: If I go the puck route, should I just put what would be 7 days worth of CL in trichlor form in the floater or overshoot a bit? I will be bumping the FC to near the top end of my maintenance target before leaving.
Q2: To cover or not to cover. I'm leaning towards covering to keep debris and UV from messing with things.
Thanks!
Thanks!
