- Jun 13, 2016
- 119
- Vinyl
- Pentair Intellichlor IC-40
The pool was great until a few days ago when we started noticing a slight haze. Here are today's test results:
FC: 3.0
CC: 0.0
pH: 7.4
TA: 225
CYA: 70
CH: 300
I'm tempted just to slam it. I did this a few weeks ago and used Clorox bleach from Costco. I can't tell if that has polymers (which can cause haziness?) in it or not. It is 7.5% sodium hypochlorite.
What's odd to me is that the pH has stayed right at 7.4 for the last few days. Usually this climbs steadily when the SWCG is in use. Any thoughts as to what might be causing the haziness?
Note, too, that the FC has stayed about the same overnight. 2.8 to 3.0 (I was running the pump on lowest speed to keep the SWCG going and had the SWCG set at 60%).
FC: 3.0
CC: 0.0
pH: 7.4
TA: 225
CYA: 70
CH: 300
