Systems powers on, pump and filter restore water flow. System ignites and catches flame...but 5-10 seconds later it shuts down. After three attempts, the system goes into the default safety lockout.
Backstory: I had this issue last season but it went away after I cleaned the flame sensor. I also had this issue at the beginning of this pool season, which coincided with water under the heater (which I mistakenly though at the time was from rain getting in the shed). After playing some more with the flame sensor, it worked and then ran all season...with no water under the heater. Then a few weeks ago the water under the heater returned and sure enough, IF code. This time I couldn't get rid of it. So I tested everything I could think of: cleaned the orifices for spider webs, checked the ignitor (working)...however the water was definitely a leak. The heat exchanger was very rusted all over and had a leak. I got most of it cleaned and then took it to a radiator shop in town that inexpensively got the leak fixed. While I was servicing everything, I also pulled the burners out...they were all quite rusty with a lot of the holes covered. I cleaned out as much of that as I could to open up the holes...seemed fine. Ran a meter on the wires for the flame sensor, continuity is there. So I've troubleshooted Dang near everything I can. The unit is 10 years old (I've had it for two). The casing (spongy?) that houses the heat exchanger and the burners is still very wet (aka not dried out) from the leak that was happening. It's now too Dang cold up here in Canada for it to dry out on its own. That wouldn't have anything to do with it stopping the flame and brining on the dreaded Ignition Fault code...right? Any help would be greatly appreciated because I don't want to throw out the unit simply because I'm ignorantly missing something. TIA
