I had someone over working on my pool and it appears they broke the screen to my Hayward controller, so Im looking for a how to turn on the pump manually? When I open the pump cover I have no power or nothing on the display. please let me know
The CB is turned on. and I only have the one screen on the controller pad. I am guessing here but I assume when I turn on the pump or filter using the controller pad it triggering a relay that powers the pump. So Do I need to bypass that relay somehow temperary
In the menu on the pump, get to "standalone" and you will have control over the pump if there is power to it and no other damage. The pump should have constant power, it is not controlled by a relay.The CB is turned on. and I only have the one screen on the controller pad. I am guessing here but I assume when I turn on the pump or filter using the controller pad it triggering a relay that powers the pump. So Do I need to bypass that relay somehow temperary
Some VSPs no longer come with their own control panel. See many Jandy VSPs.All VSP's can be controlled from their own control panel.
