I have a Hayward Super Pump 1 HP that is about 6 years olds.
The pump is still running but is very loud and squealing (guessing barrings). I was looking at replacement motors (leaving in the wet end and just replace motor - no plumbing changes) and wanted opinions on should I stay with a Hayward labeled motor, or are the other brand replacement motors that are cheaper perfectly fine. If so - any recommendations.
Also, it is a single speed 1 HP (pressure is fine), are there just motor options to go to a more energy-efficient motor that is variable speed or higher horsepower. (not sure why I would go with more HP - more of a general question I see recommendations for variable speed).
Final question - any TFP friendly / recommended sites to purchase a replacement motor from. I will install myself.
Thanks
jmcst25
other info
IG 33K Vinyl / Salt pool.
All chemicals are balanced.
Thanks
jmcst25
other info
