Good Morning, was wondering if anyone could give me some advise as to what might be wrong with my pump and the best (read affordable) solution? I am a do it your self kind of guy with some measure of experience in AC electrical - even 230v. Our pool is an 80,000lt in ground pool with a Hayward Super Pump. Will post model and hp when I get home tomorrow. It's 230v for sure tho. Age of pump is 11+ years old but looks in pretty good condition and has run flawlessly every year from 2009 till 2017.
- Pool was shut off and not maintained other than water level for 2 years.
- Opened pool and got everything ready to start pump and fix the water (took almost a whole day)
- Turned on pump breakers and pump was making a low humming.
- Gave it a few gentle taps with hammer to free impeller and no change.
- Cycled breakers off and on once - still humming, and before I could turn them off, the pump went silent.
- Cycled breakers again to reset and still silent.
- Checked AC wire going to pump with a current detection pen and they are live when breaker is on.
That is as far as I got then had to go to work. Planning on testing voltage with a volt meter and will post results.
In the meantime, any thoughts as to what happened to my pump and where to go next with it.
Hayward pumps are pricey and would rather repair than replace if possible to do for less than a new one.
Thanks for your time guys!
Paul
Paul
