I am about ready to give up and buy a new pump. I installed this Hayward Super Pump in the mid 90's and over the last couple of years it has been leaking a little. I put in seal kits on several occasions, most recently this year. This year, the second motor I put on it finally gave out with noisy bearings. So I put a new motor and seal kit on it. It still leaked a little, always on the wet side of the seal plate. No amount of re-torqueing of the bolts would help, so I bought a new seal plate and put it on this week. It had no effect whatever on the leak. I am wondering whether the pump body has a hairline crack or is warped at the seal plate mount. I have attached a photo of the leaking pump. The water is coming out at the "peak" of the seal plate where there is a little point there. In the picture you can see a little rooster tail of water streaming up. I thought I would check in here, and see if there is one more thing I can try before caving in and buying a new pump.
I have scanned the forum here, and think I have tried everything mentioned. If there is a crack I cannot see it. Any ideas would be greatly appreciated. This pump is up next to my house, and I don't like the amount of water it is now putting out near my walls and foundation, not to mention the wasted water.
Thanks in advance for any ideas.
