We just were able to look under the filter and there is a small pinhole size leak in bottom of filter housing. It is leaking water. I turned filter to closed setting and leak stopped. Can we fix the small hole or need to replace it?
If the leak is in the filter body, it is unwise to attempt a repair. Probably time for a new filter body.
It is puzzling that changing the valve setting stops it. Are you quite sure it is not coming from the valve and running down the side of the filter to the bottom?
