Hayward S3 Omni and Raypak heater
DylansNina
7
AL
We are looking at having this Hayward salt/automation system installed and I have a question regarding controlling a Raypak remote enabled heater.
The PB said the Omni can turn the unit on/off, and we would also add the valve actuators as well, but that we could not change the temp on the Raypak remotely.
From my understanding when the Raypak goes into remote mode you typically max out the temp (104 degrees) then the remote/automation can control the pool temperature by turning the heater on/off….is this correct as to how the Omni will operate in regards to regulating pool heat?
Your PB is technically correct but you don't want to change the temp on the Raypak when it is controlled by the Omni.
You are correct.
