When I started up my pool this summer I have water coming from under my 14 year old Hayward filter. I have inspected the seam and all the pipes and the cap on the drain valve and I don’t think the leak is anywhere above or outside the surface of the filter.
Is there a likely easy to identify potential source of a leak at the bottom if I empty the sand? The side mounted valve is hard to operate so I suspect it will need to be replaced soon anyway.
Looks like I could have a new one with a new valve delivered by Wednesday. At 14 Years am I likely better off to replace it or is the life of a filter a lot longer than that?
Thanks for the guidance.
Geno.
Geno.
