A quick question. I have an in ground concrete pool with a DE filter and i use an older model hayward robot cleaner. In order to get sufficient suction i have to cut off the bottom drain and 1 skimmer when i vacuum. My question is, do i need to turn off the filter before i cut the skimmer and then turn back on or can i just turn the knob that shuts the skimmer while the filter and pump are still running ? I'm always afraid of breaking a pipe if i cut it off while it's running.
Thank you
Thank you
