I have a Jandy 3-way valve that diverts water from a dedicated vacuum port and the skimmer on the suction side. This is the only way I've been able to control the amount of suction going to the vacuum. If I want more suction to the vacuum, I get less suction from the skimmer (and visa versa).
So, I would like more independent control of the suction for the vacuum and skimmer. I purchased a Hayward V094 regulator valve for this purpose. With it, I was hoping I could adjust the Jandy valve for the amount of suction I want for the skimmer. Then I could use the Hayward valve to adjust the amount of suction to the vacuum. I hope that makes sense.
However, I feel like putting a non-flexible part (the Hayward valve) directly into my vacuum port may not be wise(?). If someone were to jump on it, it could break off in the port (or worse). I've only seen this valve in a few videos being connected to the skimmer via an adapter, so now I'm thinking it may not be intended for use on a vacuum port?
Any advice is appreciated. Thanks!
