- Apr 4, 2019
- 12
- Vinyl
- Hayward Turbo Cell (T-CELL-5)
Looking for some suggestions, my pool installer installed our lights in what I would call a strange way. I have a 2 part problem and am looking to upgrade and do it a better way to control the lighting.
We have a Hayward Prologic controller setup along with the color logic lights, the low voltage lines are run into a Hayward transformer box which has a manual on/off switch as well as a 3 prong plug out the bottom. The pool installer then had our electrician take this Intertek device (picture attached) which the transformer plugs into and is then hardwired it into the controller. This Intertek box seems to work similar to a smart switch, it has a small handheld remote that you can press and cycle through the colors...it works but its less than intuitive in my opinion it is similar to with walmart link but does not connect to a phone Verify your identity
Opened the pool last weekend to find out lights are not working, I plugged the transformer directly into a receptacle and they are working fine so I have to assume this Intertek box device is dead.
Hoping someone can help point me in the right direction, ideally I would like to be able to control the lighting on my phone assuming it is not to high a cost to make that happen. I suppose I could just install a smart receptacle on the controller and plug the transformer into that but I am not certain how or if that could cycle the colors it would likely just turn it on/off? If needed I can send more pictures of the set up just let me know.
Appreciate any help or suggestions, thanks
