Hi, hopefully someone has some advice on my issue. I have a Hayward swimclear cartridge filer that quickly fills with air, I can bleed the air out and within 5 minutes it needs bleeding. I’ve replaced all the gaskets on the suction side including the pump basket and have tested all connections (smoke and shaving cream, etc…) and can find no leaks. I’ve isolated both the main and skimmer lines to try isolate an issue with either, but the problem never resolves itself, so assume the issue is not with either line. The water is half way up the skimmer intake so water level is not an issue.
Funny, there are no air bubbles coming through the pool returns and the water flow rate seems good but there is always air to bleed out of my filter. I’m not sure what else I should be looking but there is air getting into the system somewhere
Thanks for any advice you may have.
ken
ken
