So this is something I dealt with last year with my new EC40 filter and I'm just wondering whether there's any known problems and solutions.
I was getting a small amount of DE blow through in my AGP.
I disassembled the grid completely and inspected every finger individually, they all appear to be intact. I just don't understand how they're supposed to seal properly at all given the design of the filter. At the base of the fingers they're sandwiches between two plates but they use the filter fabric as the gasket and that simply doesn't seem like it would provide a DE tight seal. I reassembled it and made sure the bolts that hold the two plates together are tight but not too tight, and I added an extra stainless washer on the so that the c clips on the shaft hold it even more tightly sandwiched in the middle too. That dealt with most of the issue and reduced the blow through a lot, but there is still some, like a few dime sized spots on the floor when I vacuum weekly.
My working theory now is that I just need to wait for the tiny leaks at the base of each finger to get clogged up with soiled DE over time.
My backwashing process is total clean out, I open the filter to remove the grid assembly and make sure all DE is removed, then load the prescribed 4lbs directly into the filter.
I contacted Hayward and they wanted to send a tech out to diagnose etc. which I'm just not interested in. I already agree with their likely conclusion that inspection of the filter reveals no specific manufacturing faults. They said "send a picture of how much DE is blowing through" so I take it they are going to say a tiny amount is within normal.
I'm swapping out a 1HP for 3/4HP this year so maybe the reduced pressure will help too.
