I've seen other threads on this issue - seems to be a common problem so hoping someone can direct me to a fix - Pool was built in 2017 and from day 1 I've never had an issue with the Omnilogic system - except for salt cell replacement and burned salt cell board - both easily fixed. However, as of yesterday, the Omnilogic screen will not turn on. I've power-cycled they system by turning off the breakers on the Omnilogic Panel; I've checked all fuses - no blown fuses - and shut the system down from the main board from 30 minutes - nothing has worked. When the system restarts the main pump will turn-on but run at a minimum speed. No access to the system through the App - which is typically how I manage pump speed, chlorinator, water features, etc. How I found out about this issue was through the disconnected mobile app message. Thoughts on why the screen will not work? Is it time to replace the screen? Thanks!
